I got the so called multifunction steering wheel and the "half display" in the dash between the gauges. The stunning this is that I CANNOT change radio stations using the steering wheel buttons, I can only change volume!
I have the multifunction steering wheel and i have no problems changing radio stations just FYI the MFD has to be set in the Audio menu. Hope this helpsI got the so called multifunction steering wheel and the "half display" in the dash between the gauges. The stunning this is that I CANNOT change radio stations using the steering wheel buttons, I can only change volume!![]()
MFD has to be adjusted with the menu button to access the HU control before u can do the track change etc, else its only volume. MFD usually has 3 menus to scroll in-between, one shows the fuel economy etc, the other the settings menuI got the so called multifunction steering wheel and the "half display" in the dash between the gauges. The stunning this is that I CANNOT change radio stations using the steering wheel buttons, I can only change volume!![]()
Indeed and it's pretty stupid from VW.well you cant do it then unless you press it on the actual radio. musn't of been wired in when you bought it.
Steph xx
Thanks man! I will apreciate.MMh I don't think it was retrofit as it was bought by a VW manager.. However it's a possibility, one never knows.
I will report what you asked but you have to be a bit patient![]()
I thought you solved that problemAnd indeed I got the half display but what's the point in retrofitting that "multifunction" steering wheel if you can't really do anything but change the volume![]()
