Hi all,
I have a 2008 EOS with 55,000 kilometers. Last week the instrument cluster warning lights went off and there was 3 short beeps. Since then I consistently have the ABS and Traction control and the tyre pressure warning lights on. Sometimes the steering warning light comes on, sometimes not. Sometimes the speedo indicator will go down to zero even though the car is moving and the same with the fuel gauge indicator.
I have had the car hooked up with VW diagnostic tool and there were so many errors. For those brave enough the list is here:
Engine Malfunction 001287,049441,001281
Auto Trans 17106, 18201, 18259, 18255
ABS brakes 01130, 00285,00283, 00290, 00287, 00668, 01279, 01423, 01542 16352
Park/Steer Assist 01317
Airbags 01316
Instruments 01316
CAN Gateway 01316
Auto Roof 01316
Navigation 03138, 00001
Steering Assist 01316
Door Elec 00933
Headlight Range 01316
Radio 03138,00001
The 2nd place I took it to (which was a VW certified repairer) said it "might" need a new ABS module. The problem is that I don't want to go and replace a $1200 part on the "might" fix it viewpoint.
Has anyone ever encountered these issues. What was the fix (hopefully it was not too expensive)
Kind regards in advance,
Airbags 01316
Instruments 01316
CAN Gateway 01316
Auto Roof 01316
Door Elec 00933
Radio 03138,00001
