Hi, I had been enjoying my 2009 1.4TSI Eos with only 54.000 miles on the clock. Although it is not great using during very cold winters as the windows freeze up. I really don't like having to Mot a car during the winter as I need to work on it outside in the cold.
After taking my car for the mot last week it passed with just 2 small advisories, however on the way back the electrics all went crazy. No indicators, wiper, horn, boot release, dashboard lights etc etc. The car was still driving well with no engine warning light on dash. The battery completely drain overnight so I carried out a few tests with the multi meter, pulling fuses to look at the readings. The amps leakage was still high although 1 x 5 amp fuse relating to the fuel pump did show a reduction when pulled out. I then disconnected the battery and put a wire across the leads for 5 mins. I now have some electrics back working with the ignition on but if I start the engine they all start to fail again.
I phoned a mobile auto electrician but he told me that he would have little success in finding the fault & would charge £60 an hour.
Has anyone experienced these problems & give any advice?
Cheers
Keith
Cheers
Keith
