Hi Guys
Can anybody help. I have wiring diagrams, but I am not getting any positive voltage to lamp M29. Standard halogen lighting. Nothing on the yellow/black wire to the headlight plug. Tried looking at the onboard supply control unit J519, but the diagram does not seem to tie up with any of the connections. J519 is 3C0937049Q.
TIA
Adrian
Fuse 6 (5A)? check them all? Also check fuses in the engine bay fusebox. V.W use different locations and values for the same model depending on options (halogen/xenon/lowline/highline etc). Look in your driver manual which is close to VIN specific.
Hi Voxmagna
Thanks for your reply. Managed to find the issue poor connection on plug to J519.
Regards
Adrian
