My 2008 Eos, 2.0TFSI, 58K miles, (engine code BPY) has been having some idling problems, system too lean condition that I thought I had fixed but it came back.
Vag codes:
ODB II:
P0171 System Too Lean Bank 1
I have no misfires, but I am seeing short term fuel trims peg at +12 % to + 18 % or more during closed loop and a bit rough idling and sometimes high 1000 rpm at idle. MAF sensor seems too low for me, it's around 2.2g/s to 2.8g/s normally I think it's 3 or 3.5??
What's interesting is that I suspected the PCV so I replaced (with cheaper aftermarket, not oem) and reset the codes and they didn't come back for about 2 weeks. Before I would clear them and they would come back within a day or shorter.
But now the problem is back. I'm wondering if I have another air leak somewhere or maybe I shouldn't use aftermarket PCV valve? I also suspected the oxygen sensors but the voltage was around 0.625 on Bank 1 sensor 2 which I believe is the downstream. It seems to be just reacting to the situation and not an issue within itself.
Is ambient air temp a factor? For some reason my ambient air temps are way too high (it was 75f outside), bad sensor?
Here's some more parameters during idle:
Vag codes:
ODB II:
