So I bought an early, fairly low mileage Eos with a non functioning roof. It wasn't a lot of money and I took it 'as is'.
The roof I can live with, plenty time to iron that out. However, I find the wipers don't work and those I need and it seems every garage and electrician is 'chokka' for the foreseeable. I've racked my brains over this, so I turn to you guys in the hope of finding the solution.
I don't have VCDS but I have acquired a loan of an old MODIS which tells me there is no signal from J400 and G397. The motor has power and ground. A look at SSP 379 seems to show the LIN for both units emanating fom J519 ( Power Supply Control Module). I've found J519 but I cannot find any wiring diagrams anywhere to check for open circuits. I can't see the motor and the sensor both having a break anyway. Should I be looking to change J519 ? Any thoughts ?
