1 - 10 of 10 Posts
Has anyone else created a photo album in the PhotoPlog section? I created one and loaded 9 photo's into a album named Virginia EOS. I know someone else has created a album but when I click on albums mine is the only one that comes up? Any more albums out there? Am I doing something wrong or is my album the only one that I can view? ?????:mad: I was looking forward to seeing everyones photo's in their album section.
Click on Photos, Albums, then under Albums if you see Virginia EOS then click on it. I moved 9 photo's into that album and they all show together. File is marked as public so you should see it . If not, then I am lost and can not find any reference as to how the album section works. Anyone have any idea?
· Everyday's an EDA
Hi Mike,
I tried clicking on the link in your signature. I gives the following error message
"Sorry, Jim: No Item or Item is Now in Moderation Queue - Check Back Later"
That may be why we can't see your album.
:confused: Thanks for the feedback. I deleted the album and created another but could not upload photo's. Do not remember how I did it the first time, so what good is the album section?
To create a album. (maybe)
-click on album list
-on left side you will see album list and under it you will see "not available".
-on right side click on add album.
-manage album box will come up and you can fill in title, and notes in description box. Now how do you upload photo's? Maybe that option is turned off by the administrator. If anyone creates a album then let me know how you did it. thanks. The next time I will write down notes.
· Everyday's an EDA
How to put photos in an Album
Hi Mike,
This seems to work.
1/ Go to photos.
2/ select Member Uploads - 'R'
3/ Select reqd image.
4/ new window opens.
5/ top right of the image is a button 'Album It!' click button.
6/ If you've already have an album you can select it from a pull down. If you hav'nt created one by default by submit you create an untitled album that you can then rename.
The toolkit button allows you to edit/rename photos etc.
Have fun.:)
Discussion Starter · #9 ·
Thanks Jim, that worked. Remember it now, must have had another one of those "Senior Moments"! Too bad you can not see any other Albums except your own.
· Everyday's an EDA
There is a privacy setting 'Public or Private' but it does seem you can only see your own albums. Means it's more like a favorite photos album.
1 - 10 of 10 Posts
