1 - 2 of 2 Posts
My 2008 1.4 vw eos roof will not come down the motor seems to be working I can't figure out what is wrong with it would anyone have an insite to what my problem maybe please
Did you buy the car with a dead roof? Did somebody open the pump valve because they knew the roof would fault if it was used? Did the seller say the pump motor works so it must have a simple fault??
Just read through the recent top 4 or 5 popular posts here to see what you could be up against and get the insight you are looking for. All the knowledge you need is there for you to start work. Otherwise, leave it to a trained technician with the right tools to solve your problem.
1 - 2 of 2 Posts
