I think VW sells more manuals percentage-wise than most other makes,
I would think Porsche sells a larger percentage of manuals than their tiptronics.
Then again, isn't Porsche now part of VW-AG?
I'm so confused...
As to the topic at hand - revving a motor to near redline won't hurt the motor, but folks who typically make a habit of doing this also drive their cars hard, and put them away wet. Slamming through the gears, downshifting to slow the car down, releasing the clutch before the next gear is properly engagd - these actions can cause more damage than bringing your motor up to redline. Having said that, red-lining a motor day in and day out will mean that your maintenance windows will be shortened - your oil viscocity will break down sooner, and engine components will need replacement sooner.
I have a Porsche 944S2 - When I'm driving it on the racetrack, I will bring the motor up to almost redline before shifting. For just about every up-shift. When I am driving it on the street, I'll shift to a higher gear a lot sooner than redline. My shift points depend on several factors, including:
1. Is the motor warmed up? (If not, I won't wind it out as much)
2. Am I in the mood for some spirited driving?
3. Am I near the end of my journey? (If so, I'll not rev it much much, to allow the car to cool down a bit)
4. Am I in a hurry? Do I feel like accelerating briskly?
5. Am I just cruising around going nowhere fast?
Keeping the car in a lower gear past the 'peak hp' revs will still allow the car to accelerate faster than shifting to a higher gear. Acceleration is based on many factors, including torque, and gearing. (Horsepower is more of an issue with regards to top end speed). At a given speed, a lower gear will almost always offer greater acceleration than the next highest gear (provided that either gear won't put the motor in an over-revving situation, of course!)
Regarding downshifting: first off, one must NEVER downshift to slow a car down. There is a far cheaper system which was designed for this -- it's called the brakes. A bit of history trivia - in years gone by, when MG's, Minis and Fiat Spiders were the norm on racetracks, they would use downshifts to slow the cars down. Why? Because after a lap or two, their miniscule brakes would be ineffective, and in order to slow the car enough for the corner, the drivers would use whatever means possible, including downshifting. In modern racing cars, a downshift is accompanied by a heel-toe rev-match blip of the throttle - this is done so that the decelleration attitude of the car is not effected by the downshift.
So - when does one downshift on the roads? like stated above - it all depends on many factors. It depends on what you need the car to do - if you need to accelerate away quickly to avoid an accident, then grabbing a lower gear sooner is better. If you're trying to prove that a VW Eos is a better alternative than a Toyota Prius in terms of gas mileage, you may want to stay in the higher gear longer.....
Sorry for the long post,
-Z-man.
