I was going to install an iPod adapter and found some text directions which basically said to remove the radio trim then remove the four screws that are behind the trim.
What is the best way to remove the trim without scratching or denting the chrome?
I used an old credit card. Slip it behind one of the corners and twist. Keep working around the outside until it pops loose. Be careful with the center strip.
Once you get the trim off, you'll need a torx bit to pull out the head unit.
