The RCD510 SD input is specified as accepting SD cards up to 2Gb in size.
When I first tried a 2Gb card loaded with tested mp3 files, I received an error message saying the card could not be read. I then tried a 1Gb card with the same files which worked fine.
After some detective work, I discovered the 1Gb card was formatted with the basic Windows FAT file system whereas the 2Gb card had been formatted with the later NTFS file system. Reformatting the 2Gb card to FAT and reloading the files proved successful.
If you experience problems with card read failures, checking the card format to make sure it is in the windows FAT file system should be the first step before blaming the card/multimedia system.
Now to see if I can get the system to play 4Gb SD cards
