Refurbishing/ updating side view mirrors
647 Views 12 Replies 3 Participants Last post by  voxmagna
My sideview mirror are a bit beat up from the Florida sun. Peeling clear coat on the covers and the housing has a lot of chipped paint. I was going to look into finding new/ used but they're in the same shape as mine and still pricey.
To test it, I took 320 grit sandpaper to the housing while on the car to see how they smoothed out. I was surprised how smooth it was after just 10 seconds of sanding. So I decided to take a chance and rebuild them with some upgrades. Ill prob scrape the old black paint off, sand, primer and paint. I will clean and lube any hardware as well.
The covers you can find all over ebay so i didnt need to look far. Would be an easy remove/ replace. I may get these Carbon Fiber ones.
Ebay also has these LED puddle lights and signal lights available. pretty cool and very cheap for a quick update. Links below...
Im out of town for a couple weeks but will update you when I start the project. Im still doing research on the actual parts. I'm pretty set on these CF covers but the LED upgrades i need check more on. Hope this can help some of the other people dealing with similar issues.
Hood Automotive tire Automotive lighting Automotive exterior Vehicle door
CF covers-
LED Puddle Lights-
LED Signals-
See less See more
1 - 13 of 13 Posts
CF covers-
LED Puddle Lights-
LED Signals-
Yes i saw your video. Very cool
Professional prime and powder coating isn't that expensive? V.W didn't use an ali etch primer!
The mirrors will hold up way longer now the car is garaged so im not going to go crazy. Rattle can it is lol
The mirror glasses will become unstuck and fall off next. :)
Yes, the glue that holds the actual mirror glass to its plastic base is definitely suspect, just as the glue that holds the vinyl on the door panels is.
Everywhere I meet parts on my EOS that are glued, the glue is very poor. With all the high tech. design they put into their cars you would expect them to team up with 3M and use decent products fit for purpose? Many car body assembly methods now use glue instead of welding, rivets, or bolts. I hope V.W and Porsche aren't using the same glue.
Agreed on the door vinyl, but also the long black plastic top section they stuck to the door card. I've never found a decent hot melt glue and they seem to use a lot of it. The usual shop hot melt is fine for kids craft work, but I think there are some special hot melt glue sticks which I've been meaning to try out. Until then I use silicone.
  • Like
Reactions: 1
I used Gorilla Glue hot melt glue sticks to repair the top plastic section of the door cards. Seems to be holding up well.
See less See more
  • Like
Reactions: 2
getting my door cards reupholstered in a couple months. OEM glue is def an issue
Whomever is going to reupholster your door cards will use a quality glue I am sure. Most upholstery shops know what works best.
  • Like
Reactions: 1
3
Was able to do the paint work this weekend on my sideview mirrors. Disassembled, scraped and sanded the base the best I could. Cleaned, primed and painted with black semi gloss. Added new LED puddle and signal lights. Also replaced the old mirror covers with CF covers. I think it came out pretty good and happy with the results.
I did have to cut and solder the wiring for the puddle light as the wiring harness was too big to fit the new light in place.
Hood Automotive lighting Input device Motor vehicle Peripheral
Furniture Hood Automotive lighting Motor vehicle Automotive tire
Wheel Car Tire Vehicle Plant
See less See more
High temperature 3M spray glue. I'm going to do mine and see if I can use some small staples. Interested to know how it works for the OP because every way I look at it you can't avoid separating the top section of the card (A zillion blind rivets) and they will have to stitch a panel in on the ends.
1 - 13 of 13 Posts
