anyone advise of a good silicon grease available from halfords or the like
If you look through the thread "Drip,drip,drip" you will see numerous references to a material known as krytox which is available from VW dealers, but expensive. Also reference to a similar material from GM which is less expensive. Comments seem to indicate it works! Good luck!anyone advise of a good silicon grease available from halfords or the like
Please please please....anyone advise of a good silicon grease available from halfords or the like
i stand correctedpage 25 says
"if it is cold, dry the rubber seals and the surfaces they touch with a cloth to prevent them from freezing. Treat the rubber seals with a silicon spray-this does not apply, however, to the seals on the CSC roof"
Page 26 says
"Please do not use any silicon-based rubber care products or cleaners which contain acids on the seals of the CSC roof, such as industrial dust cleaners or insect removal products."
Thanks WKC,Just in case anyone don't bother to read the manual...
It reads "Do not use any rubber cleaning or treatment products containing silicone, OR
any products containing acides"
Do NOT use any silicon based product!
