Hi im having problems with my 09 eos roof. The roof folds without any issues however the boot will not close. It's as if it's forgotten what to do. I can put the roof back up with no problem and the boot closes as it should. Has anyone had this issue. Any and all information would be greatly appreciated, many thanks.
You need V.W compatible diagnostics and then learn how to use it. Any other suggestions will be guesswork. These are very complex cars.
justcarkits
The roof sequencing is complex, but sounds like a hall sensor, microswitch or wiring issue. Boot closure will not engage if any of the roof sensors do not detect correct roof state.
Without VCDS or equivalent you will be spending hours on guesswork.
Needs to have fault codes read to make progress.
