Seeking Opinions: 2013 Volkswagen Eos White Convertible - Your Input Needed!
4.9K views 9 replies 8 participants last post by  voxmagna
There have been many good ideas passed along. Since you appear to be the third owner, A PPI is definitely a good idea whether by a dealer or a company that specializes in that service. Pull everything from the trunk and look for signs of past leakage. Use your nose to see if you can detect any mustiness which can indicate leaks. If the current owner will okay it, take it for a test drive and through a normal car wash, not a high pressure one. Checking the roof operation is a must. If they have maintenance records, check the trans has been serviced as well as all fluids done. With proper care, you should get many miles of happy motoring. We are approaching 150,000 miles on our 07 which we bought new in the fall of 06. We have kept up the maintenances and it has been costly as most work has been done by a dealer. Car has driven well and is a lot of fun. The turbo four makes reasonable power. even without boosting the power with chipping, you can break the tires loose without much work. If you follow all of the advice you have been offered, you should be able to enjoy the car for a long time.
  • Love
Reactions: King789
