Hi guys, I have no idea how this happened, but the little plate with the clip that keeps the sun visor in place worked itself loose and fell out. There are screws, but the heads are covered with a plastic piece so I am not sure how to screw them back in. Is the plastic piece meant to pop off and back on? Do I need to buy a replacement kit? Such a minor annoyance, but I hate to pay someone to fix it if I can do it myself.
I know that the plastic pieces can be taken out - the normal way to get the whole piece of the trim :D:rolleyes::D
But there must be something wrong with the trim, normally it is attached pretty good!?!
Look at the second photo - at the bottom you'll see a little lip where you should be able to insert a screwdriver, lever the base off and get to the screw hole. Once you've screwed the bottom part back in, you can clip the top part back on.
