Still totally impressed after the first month. Fantastic car.
Anyway, on topic.
Upon perusal of the owner's manual Section 3.3 - Technical Data I noticed that there seem to be two different spec TDI engines.
#1 carries engine code BMM and has the more "Diesel"-typical characteristics of 320 Nm from 1,800 - 2,500 rpm with 103 kW at 4,000.
#2 carries engine code CBAB, and slightly different specs: 320 Nm from 2,500 - 3,000, 103 kW at 4,200 - closer to petrol characteristics (note: "closer", but note "close").
Incidentally the performance figures are identical but fuel economy is slightly better with the CBAB engine.
Our Eos (candy white, I might emphasise for the benefit of our British friends ;-)!!) has the second spec. It seems to revv quite freely (even after only 1500 kms), and it only occasionally sounds like a Diesel but most of the time does not sound like a petrol (and not like a Diesel either).
Has anyone with a Diesel checked their engine codes? Is this the difference between a PD (BMM) and common rail (CBAB)?
Comments welcome.
Wish I could drive more often. Yesterday was a perfect day here in Melbourne, and I managed to get the Eos over the Passat. Drove home with the roof down - so much fun. Enjoy this time of year, northern hemisperians!
Regards,
Michael
Anyway, on topic.
Comments welcome.
Regards,
Michael
