After successfully upgraded my 2009 EOS low beam with HID on my previous post, I have decided to try improving the high beams as well and came across this excellent LED kit, the "Light Moses 360 Degree LED Headlight Bulbs Conversion Kit High Low Beam - H7" from Amazon, which fits perfectly into the high beam housing and is insanely bright. It literally turns night into day when I turn on my high beams.
The kit including the bulb and drivers is a slightly tight fit when trying to put into the housing, but take your time and slowly position the unit and cables, and it will defintely fit, and you can close the dust cover with room to spare.
These are 45W LED bulbs which are canbus ready and will not cause any bulb out warnings. These bulbs are also 360 degree with 5-sided LED instead of the older 2-sided design and the beam pattern is excellent on the reflector headlights. The color is also a very nice bright white, making the colors of everything the light shines on pop with high contrast.
Together with my low beam HID lights, these lights truly transformed my night driving. I am truly enjoying my night drive and have absolutely no fear of going anywhere in my EOS after dark.
Disclaimer: I have no affiliation with any of the products above except as a happy customer and hope to be able to help other EOS drivers.
