1 - 13 of 13 Posts
I recently leased a new 2007 EOS with the 3.2 V6 and the DSG automatic transmission. I'm slowly getting acquainted with this special vehicle that has so many personalities. I have found that the User Manual does not always describe the car I purchased. And there are things on my vehicle not found in the user manual.
Does anyone know what the square button marked "W" in the bank of buttons with the "ESP" button do? When pressed a light indicating "on" lights.
Help!
Could have lit up a sign saying "please do not press this button again" ( only Douglas Adams fans will properly get this ;) )
Unknown Buttons
Whatever it does it can not be as exciting as someone (blonde, you bett'cha), 12:00 PM, neighbors asleep, after garage door is closed, holding key switch and softley asking....."this button called PANIC, what does it do? ...............30 seconds of complete chaos !!
If it's the same as the Golf GT I recently had, it's the Winter mode for the DSG. Try pressing it and then accelerating hard. You should find that it will not lot you lay down too much power, in order not to slip in the loose stuff.
Mystery Button
Help!
Hi
The only other other button sited next to the ESP button on my EOS with DSG, is the soft tyre indicator reset button, could this be the button you are referring to?
Bill
Speaking of unknown buttons, has anyone else noticed a button on the drivers door, underneath the armrest above the storage space? I have one there and have no idea what it is for!!
Hi Darren, the button under the arm rest has something to do with the alarm system, not sure what though, it tells you about it in the handbook.
Paul
It is for disabling the internal movement sensors (if fitted)..... You press it before yu get out and, when you set the alarm, the sensors will be disabled. This allows you to keep a pet in the car and their movement won't set the alarm off!
1 - 13 of 13 Posts
