Hello
I'm the second owner of a VW EOS 2.0 FSI (1F7) from 2007, from the beginning It had some times a rought idle with engine kicks, the engine is always at 700 RMP at idle.
I want to ask if any of you have the same model, what's your engine idle RPM so in case mine is wrong I can try to change it.
I think the first owner maybe changed some settings of the engine to go on lower RPM but I want to ask you first to be sure before doing any change, if you can provide me also your "Idle Speed Adjustmen" value It would be helpfull too.
Thank you very much in advance!
From this point you can skip the rest of the post because it's all the things changed/checked on the car just in case some one has another point of view of the issue and could give it
The car has been at three different shops and no one has found what can be happening, it end up breaking the engine mounts and had to replace them last month. It was a whole month with an Audi technician doing tests to the car and nothing found.
Here is a list of the manteinance made to the car, but the problem was already there before doing this repairs:
There is a situation where this problem doesn't happen, when it's really cold outside and high relative humidity (6ºC and close to 90% humidity).
- The EGR valve is new.
- All four ignition coils and spark plugs are new.
- The charcoal canister and purge valve are new.
- The engine mounts are new.
- The timing belt kit has been changed including the water pump.
- The oil has been changed.
- There is no errors recorded.
- The engine has no leaks.
- The computer has been checked two times and it's fine.
- The engine timing has been checked and it's fine.
- The knock sensor has been checked and it's fine.
- The lambda sensor is fine.
- The injectiors and the injection rail pressure are fine.
- There is no leaks on the escape.
