We have a new 09, picked it up the end of November. The temps here have been around -26.1° C (-15° F). I went to use the wind screen wash and found it would not work. Looked under the hood and it was frozen solid. I put the car in the garage with the heat, on and it did thaw, and the pump worked. All was good. I was wondering if anyone else had any idea what grade of solution they use from the factory. Around here everything is at least -20° F rated.
Second question, is anyone aware of where there would be a drain plug on the tank so I could drain the bad stuff and replace with new?
