I know is possible I already collected some info in jobs done, however are for GolfV and Passat 3C.
Mainly is needed:
- 2 VW original bi-xenon headlight
- Especial cabel from Kufatec who convert halogene cable to connect to xenon
- Activate the bi-xenon with VAG-COM
Can be added:
- VW original auto level rear sensor
- VW original auto level front sensor
- VW original AFS module (auto level plus cornering)
- Cables from Kufatec that connect all this
- Adjust the xenon ligh by VAG-COM
And also add Jet spray:
- VW original 2 spray heads
- VW original 2 cylinders
- VW water pump for jet spray
- Water flexible pipes and connections
- Cable from Kufatec
The more expensive are the bi-xenon headlights.
EDIT: I did it. Bi-xenon headlights, Kufatec harnesses (very bad support! and error on wires cable), AFS module, autoleveling sensors, headlights washers and minimum water tank level. It's 99%, no errors but cannot do headlight level adjust by VAG-COM as it saying "Reg.Posit Learned", is only mechanically adjusted.
Mainly is needed:
Can be added:
