Hello all,
I've looked around on the forums for any threads relating to a gap between the front window and the rear window.
My front window appears to "bow" out, just enough to cause a gap between the front window and the seal on the rear window.
The gap is about a millimeter or so - just enough for road noise from the outside to annoy me.
It seems to be a bigger problem on the driver side - though I never really sit in the passenger side when the car is moving so it may be a problem there too.
If I reach back and push out on the middle of the rear window, the window will flex just enough to close the gap and close the seal.
I had the dealer attempt to fix it. He says "it was a common problem on convertibles" and that he adjusted the window. I don't think that was an acceptable answer and there was no improvement from his "adjustment" (if he even did anything).
I poked around at the seal little bit and noticed it is hollow. I was thinking of pushing some batting or rope up the inside of the seal to get it to expand out and close the gap.
Anyone have this problem? Anyone find a good solution?
Thanks all!
E
Thanks all!
E
