Hi to all.
I am from Greece so i am sorry for my English!!!
My problem is that when i unlock the car, or when i try to open the door the windows won't roll down.
The same happens when i remove the key from ignition.
Roof works perfectly. Windows goes up and down with no problem with switch.
I make the vcds coding to open the windows with keys, untill i find the solution.
Thanks for your time
TIA!!!
Do you hear any noise from the window motor when you open the door?
If everything is 'fine' you should hear the door window motor operate, even though the window may not drop. If it's not fine you won't hear it. It is an important question to answer.
Sorry can't help, maybe somebody else can? Insufficient information to determine if problem is mechanical or electronic.
