... as part of the roof sequence or if I use the single switch that does all 4 windows. There is about 8mm of each main window still showing and the rear windows are out of sight but still press slightly on the outer black rubber seal making it bulge a bit.
If I then press each individual switch in turn they drop down that last little bit and all 4 fully retract out of sight leaving all the rubbers flat (as they should look).
Anyone else get this??
