I recently bought a JVC AV60BT and it is freaking awesome.
I ordered a wired backup camera to use with it. What I cannot figure out or find any instructions on, is the best way to run the wires from the trunk to the rear of the dash so I can make my connection.
I asume I will need to remove some floor panels but I would really like to see how someone else has done it so I don't re-invent the wheel and probably break something in the process.
Hi rauls4 when I wired my R/C I ran the cables down the drivers side and under what I think you guys call the rocker panels (sill covers here), following the rear wiring loom (harness). I lifted the rear seat cushion and undid the lower back rest bolts so as to pull the rear seat forward enough to follow the wiring into the boot (trunk area.) Here you will have to remove some of the lining to gain access. It wasn't that hard maybe an hour or two. ****
