Haven't found a simualr situation, so posting up here;
The problem I am having is the boot is completely non-functional. It acts like it is perminantly locked, and does not open via the central locking, remote central locking, boot badge or drivers door switch. IT did this once before, about a month after owning it, but had righted itself the next day and I put it down to a blip as I'd been using the roof so much.
This time, the problem has stayed, so;
Stripped the boot apart and saw corrosion around the data plug for the roof module (plug 3rd from the right as I look at it) and also around the boot latch plug.
Taken both out and cleaned as best as possible with contact cleaner and cotton buds/jewellers screwdriver. Everything reconnected, and the boot did operate for one "rotation" which leads me to think the corrosion is the problem or maybe a broken wire.
Tested the self close motor by pressing in the latch manually and locking the car,and the motor pulls the striker down, unlatch using the manual release on the latch itself, the striker comes back up.
Disconnecting the plug on the latch and the roof module results in movement from the striker depending on if connected/disconnected and position of the latch.
VCDS shows 1 fault, 02805 - System Interference , although the switch on the drivers door shows as operated when pulled and checked on measuring blocks. Full car scan attached (infotainment is currently out of the car for some work)
There is no eletric clunk or noise from the boot when locked/unlocked by any means, however when I close the boot the self close motor pulls it down without a problem, it shows closed on the DIS and when I pull the emergency release it pops up fine, shows open on the DIS as well.
From doing some reading, I think the latch plug has a connection for an electric release, and if so, could be a bad connection? Seems strange its just one pin in the harness though? I have replaced the latch mechanism and still the same, so thats one part eliminated at least.
Wednesday,13,May,2020,16:42:04:54836
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ1FZBV014574 License Plate:
Chassis Type: 1F-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 37 42 44 46 52 56 61 62 72
77
VIN: WVWZZZ1FZBV014574 Mileage: 106110km-65933miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 GA HW: 03L 907 309 N
Component: R4 2.0l TDI H24 9977
Revision: 41H24--- Serial number:
Coding: 00190012040501080000
Shop #: WSC 29035 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018GA 003006
ROD: EV_ECM20TDI01103L906018GA_VW36.rod
VCID: 6FBA260157106F33BA8-803A
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 563B6008092300FE6A1006EB901D0092350000
Shop #: WSC 00020 790 00000
VCID: 76B4136528CA5EFB79E-8022
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000000003
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 3D26CC494DFCCDA3784-8068
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0048
Revision: BC011001
Coding: 48000A3BEA27F06040080080350081EC47F10008412005206480C7000041
Shop #: WSC 00020 790 12345
VCID: 3B22C2515368C393460-806E
Subsystem 1 - Part No: 1Q2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 02031 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 090411 05 54 0403
Coding: 0730CD
Subsystem 3 - Part No: 1Q0 951 177 C
Component: Innenraumuebe 200 0203
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Coding: 000000
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 1Q0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H02 0005
Revision: -------- Serial number: 32901106204482
Coding: 10C001
ASAM Dataset: EV_EPHVA14VW4650000 001003
ROD: EV_EPHVA14VW4650000.rod
VCID: 75B61469354C55E3704-8020
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 B HW: 1Q0 959 655 B
Component: 0Z Airbag VW8C 0210
Revision: 92011021 Serial number: 003G2000JDU/
Coding: 0012378
VCID: 3B22C2515F68C393460-806E
Subsystem 1 - Serial number: 6332SRB40D5BD392B
Subsystem 2 - Serial number: 6342SRB40D5E5023+
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 AH HW: 5K0 953 569 A
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110401301440
Coding: 0082040000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 73B22A713B384BD35E0-8026
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 1Q0 920 975 A HW: 1Q0 920 975 A
Component: KOMBI H20 0420
Serial number: 00000000000000
Coding: 171F01
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 3332EA717BB80BD39E0-8066
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 060411F6001126
Coding: 355001
Shop #: WSC 12345 123 12345
VCID: 313EE079812439C3ECC-8064
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 147
Mileage: 106118 km
Time Indication: 0
Date: 2014.10.04
Time: 16:23:07
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8C37156CF28A1BED6-803E
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 F HW: 1Q0 959 255 F
Component: Verdecksteuergeraet 0854
Revision: 0033100Q Serial number: 110750625
Coding: 0655374
1 Fault Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 147
Mileage: 106118 km
Time Indication: 0
Date: 2014.10.04
Time: 16:25:51
Freeze Frame:
Voltage: 12.90 V
Voltage: 12.90 V
Voltage: 4.90 V
Error Code: 12
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2152
Coding: 0152247
VCID: 392ED8595554F18354C-806C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 3430E96D72360CEB87A-8060
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0152502
VCID: 3A2CC7555052FA9B5D6-806E
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: 71BE207941A479C3ACC-8024
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370210383
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1Q0 959 811 B HW: 1Q0 959 811 B
Component: Tuer-SG 004 0602
Coding: 0131216
Shop #: WSC 00020 790 1012544
VCID: 3536D469794C15E3B04-8060
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1Q0 959 812 B HW: 1Q0 959 812 B
Coding: 0131216
VCID: 3634D365644A1EFBB9E-8062
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:40, VBatt start/end: 14.7V/14.7V)-----------
www.Ross-Tech.com
77
Revision: 00H31001
Revision: 00012001
Coding: 0000000003
Revision: BC011001
Coding: 009795
Coding: 0730CD
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 10C001
Coding: 0012378
Coding: 0082040000
Coding: E20000
Coding: 171F01
Coding: 355001
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 147
Mileage: 106118 km
Time Indication: 0
Date: 2014.10.04
Time: 16:23:07
Serial number:
Coding: 000000
Coding: 0655374
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 147
Mileage: 106118 km
Time Indication: 0
Date: 2014.10.04
Time: 16:25:51
Freeze Frame:
Voltage: 12.90 V
Voltage: 12.90 V
Voltage: 4.90 V
Error Code: 12
Cannot be reached
Coding: 0152247
Revision: 00H20000
Coding: 0152502
Address 56: Radio
Cannot be reached
Coding: 030B185A
Coding: 0131216
Coding: 0131216
Cannot be reached
